Gypsyjon
Jan 12, 2026Aspirant
DIAABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link. I am told must disable AP Isolation, howver that is not an option wh...
Gypsyjon
I have a Netgear Nighthawk CM3000 and an eero mesh networtk.
It has wifi just fine, 2g and 5g.
AP isolation hopefully will solve my problem
I never had this problem when I was using the Mediacom router but since I switched it seems that I have had problem after problem.
I am a ham radio operator and have lots of stuff that will only use 2g.
Gypsyjon
I am trying to connect to Shark RF link to access my Shark RF M1ke DMR transceiver which. The Shark RF link is used to control the M1ke. I requires the my computer and the M1ke both be on 2g which is no problem, I can easily switch from 5g to 2g. Lots of my ham stuff only use 2g.
