Gypsyjon
Jan 12, 2026Aspirant
DIAABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link. I am told must disable AP Isolation, howver that is not an option wh...
Gypsyjon
So back to my original question, how do I diabel AP isolation on the CM3000??
Jan 12, 2026Guru - Experienced User
Gypsyjon wrote:So back to my original question, how do I diabel AP isolation on the CM3000??
"AP" means "WiFi Access Point" The CM3000 has no wifi radios, so that setting doesn't exist. All the CM3000 does is connect your Eero router to the internet.
Who told you that you need to do this?
Gypsyjon wrote:The pi-star device is called a Zumspot and uses a raspberry pie
Ok, so how exactly is the Zumspot connected to your network? Is it connected with ethernet to the Eero? Or is it connected to the Eero with WiFi?
Note you can only connect one device to the CM3000 ethernet. So you only connect the Eero to the modem. Any other ethernet needs to be connected to the Eero.
Can you reach the Zumspot dashboard from your PC?
Gypsyjon wrote:The Shark RF link IP address is 192.168.10.22
This is connected to the Eero WiFi?
