ced1971
Jun 23, 2019Aspirant
Difference between c7800s
Hello all, Can someone please explain to me the difference between the: c7800-100nas and the c7800-200nas I'm struggling to find anything on it via google, other web sites and being that ...
antinode
Jun 23, 2019Guru
> [...] difference between the:
> c7800-100nas
> and the
> c7800-200nas
Normally, that digit would denote the hardware version: C7800[v1] and
C7800v2. A quick visit to http://netgear.com/support does not suggest
the existence of a "v2", so it might be very new (or at least too new
for Netgear's apparently retarded web site).
ced1971
Thank you! I like you couldn't figure it out...makes sense v2 but who am I...I'm just a peon in the world of buying a decent modem :) I think I'll just stick with the CM1200 and buy a separate router to do the trick.
- FURRYe38Jun 23, 2019Guru - Experienced User
The 1200 is a good modem. Broadcom based.
It's recommended to have a stand alone modem vs a modem router combo unit.
ced1971 wrote:Thank you! I like you couldn't figure it out...makes sense v2 but who am I...I'm just a peon in the world of buying a decent modem :) I think I'll just stick with the CM1200 and buy a separate router to do the trick.
