ced1971
Jun 23, 2019Aspirant
Difference between c7800s
Hello all, Can someone please explain to me the difference between the: c7800-100nas and the c7800-200nas I'm struggling to find anything on it via google, other web sites and being that ...
ced1971
Jul 01, 2019Aspirant
So after even further research I still couldn't tell the difference between the two of them. I then started researching other posts. According to previous posts nas100 is version one, where as nas200 is their version two. At this point I would add why buy that when if it's not a major outage, I'd wait for a 802.11ax version which I think will be sooner than later.
antinode
Jul 01, 2019Guru
> [...] nas100 is version one, where as nas200 is their version two.
That's -100NAS and -200NAS.
> [...] At this point I would add why buy that when if it's not a major
> outage, [...]
The non-psychics in your audience might have no good idea of how
urgent your need might be.
Another thing to consider is that "newer" and "better" are spelled
differently for a reason. You can expect a "v<N+1>" model to cost less
to manufacture than a "v<N>" model; there's no particular reason to
expect any other kind of improvement. For example, I've seen no
evidence for the D7000v2 being better in any way than the D7000[v1].
(No dedicated WAN/Internet Ethernet port, more firmware bugs, ...)
