dnigrin
Jun 26, 2022Aspirant
Differences between C6300v2 and C6300?
What is/are the difference(s) between the Netgear C6300v2 and C6300 modem/routers? Thanks in advance.
Jun 26, 2022Guru - Experienced User
Its usually either along the lines of a die shrink, board optimization, change in memory, or even just a form change.
Its specs/performance should be right around the same.
