Liquidtravel
Sep 29, 2019Aspirant
Differences between Nighthawk AC3200 X4 Wi-Fi Router C7500 and the Nighthawk AC3200 X4 Wi-Fi Router
Hello all, I am trying to find out the differences between Nighthawk AC3200 X4 Wi-Fi Router C7500 and the Nighthawk AC3200 X4 Wi-Fi Router C7800. I can find reviews of each but the C7800 seems ...
Sep 29, 2019Guru - Experienced User
You can download the spec sheet for each model here:
https://www.netgear.com/support/
Type in the model# then select "Documentation".
- LiquidtravelSep 29, 2019Aspirant
thanks. So the only real difference is the DOCSIS 3.0 vs DOCSIS 3.1 cable modem?
- FURRYe38Sep 29, 2019Guru - Experienced User
IF thats what you see in the spec sheets...
