2muchcat
Sep 03, 2023Aspirant
Disable 5G on C7000v2
is it possible to completely turn off the 5G (or to disable the 5G AP) on a netgear C7000v2? seems like I've looked everywhere in the firmware and can only find the place to disable 5G SSID broadcast...
- Sep 03, 2023
thanks for the response, but I don't see smart connect anywhere in the firmware. the option to turn off the 5G guest network is right there in the settings. I don't understand why there doesn't seem to be a way to turn off the primary 5G network. that just seems crazy to me. thanks again for trying to help, though!
Sep 03, 2023Guru - Experienced User
Try disabling Smart connect first.
Then look under Advanced Tab/Advanced Settings/Wireless Settings
2muchcat
