2muchcat
Sep 03, 2023Aspirant
Disable 5G on C7000v2
is it possible to completely turn off the 5G (or to disable the 5G AP) on a netgear C7000v2? seems like I've looked everywhere in the firmware and can only find the place to disable 5G SSID broadcast...
- Sep 03, 2023
thanks for the response, but I don't see smart connect anywhere in the firmware. the option to turn off the 5G guest network is right there in the settings. I don't understand why there doesn't seem to be a way to turn off the primary 5G network. that just seems crazy to me. thanks again for trying to help, though!
Kitsap
Sep 03, 2023Master
2muchcat wrote:is it possible to completely turn off the 5G (or to disable the 5G AP) on a netgear C7000v2? seems like I've looked everywhere in the firmware and can only find the place to disable 5G SSID broadcast. ps it was easy to disable 5G for the guest network, but I don't see the same option for the primary 5G network. thanks!
I do not think your C7000v2 has smart connect. Go to the Advanced Tab -> Advanced Setup -> Wireless Settings. There are check boxes to enable/disable either the 2.4 GHz or 5 GHz wireless bands. The attached screen snip is from page 79 of the manual. You can get your own copy by clicking on the Downloads section at the top of this page, feeding in your model number (C7000v2). The User Manual is a PDF download.
- 2muchcatSep 03, 2023Aspirant
thanks! the edit button for 5G was grayed out so I thought I couldn't change anything there. went back and tried unchecking Enable Wireless Gateway Radio (and BFR/BFE) box, and using the apply button at the top instead of edit. seems to have worked! hopefully it's actually off, now. still wonder why they didn't just have an Enable box in the regular settings, as they do with the guest networks. thanks, again!
- FURRYe38Sep 04, 2023Guru - Experienced User
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
