Gypsyjon
Jan 12, 2026Aspirant
DISABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link.
I am told must disable AP Isolation, howver that is not an option ...
Gypsyjon
Everything is exatly the same. I was using ther eero before and everything was fine. The eero continues to work fine too.
I am hoping that if I disable AP isolation my computer will be able to access Shark RF link, which I use to control the DMR radio.
If you are not familar with DMR basically it is a system that allows ham radio operators to talk literally around the world via an internet link. In fact I was just chatting with guy in Chine not 5 minutes ago.
