Gypsyjon
Jan 12, 2026Aspirant
DISABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link.
I am told must disable AP Isolation, howver that is not an option ...
Gypsyjon
I have a Netgear Nighthawk CM3000 and an eero mesh networtk.
It has wifi just fine, 2g and 5g.
AP isolation hopefully will solve my problem
I never had this problem when I was using the Mediacom router but since I switched it seems that I have had problem after problem.
I am a ham radio operator and have lots of stuff that will only use 2g.
Jan 12, 2026Guru - Experienced User
Gypsyjon wrote:I have a Netgear Nighthawk CM3000 and an eero mesh networtk.
Did you install the Eero at the same time as the CM3000?
This sounds like an Eero issue.
