Gypsyjon
Jan 12, 2026Aspirant
DISABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link.
I am told must disable AP Isolation, howver that is not an option ...
Gypsyjon
Actually the CM3000 has everything to do with the radio. The radio is basically a wireless device that connects to the wifi via another device called a Pi-star device, which connects via 2g to my wireless network.
- FURRYe38Jan 13, 2026Guru - Experienced User
Not that it needs repeating however the CM series model modes are MODEMS ONLY. They have zero router or wifi features. For AP Isolation, you'll need to contact your wifi router mfr for help and support information regarding there products, i.e. EERO, if you have that router system with the CM series MODEM. The CM series Modem has zero to do with any wifi radios.
- GypsyjonJan 13, 2026Aspirant
Ahhhh hah!! You are correct, I was not aware that the CM3000 does not include WiFi.
I am thinking as someone suggested that it is an eero problem which I think is correct.
I just ordered a Netgear router which will be here Thur at which time I think I may abandon the eero.
THANK YOU EVERYONE FOR YOU HELP ON THIS MATTER. Maybe I should stick to ham radio and let the computer stuff deal with its own issues... ;-)
Hopefully new router will work better for you.
Ah yes, how I remember the days of morse code and teletype and voice. More simpler times.
