Gypsyjon
Jan 12, 2026Aspirant
DISABLE AP ISOLATION ON CM3000
Since I started using this modem, many of my devices are not happy. SharkRF M!ke for example. I can not access shark rf link.
I am told must disable AP Isolation, howver that is not an option ...
Jan 12, 2026Guru - Experienced User
Gypsyjon wrote:I have a Netgear Nighthawk CM3000 and an eero mesh networtk.
Did you install the Eero at the same time as the CM3000?
This sounds like an Eero issue.
Gypsyjon
The eero was in use prior to the router switch over and seamlessly hooked up to the CM3000 and continues to work fine.
