bengggggg
Jan 02, 2021Aspirant
Disable IPv6
I'm trying to disable IPv6. However, the C3700-100NAS doesn't seem to have that function?
bengggggg
OK, sorry about that
Jan 02, 2021Guru - Experienced User
In the system deligated prefix, is there a drop down menu to the right side of this feature screen? There should be a drop down menu. One option should be disable.
- benggggggJan 02, 2021Aspirant
I thought there would be, but sadly no.
- FURRYe38Jan 02, 2021Guru - Experienced User
Nothing is seen using a dfiferent browser? IE11, or Firefox?
If not, not sure if it can be then. Something to contact NG support about and see. IF you have any devices that are using IPv6 or getting IPv6 from the modem, just disable this on these devices.
- plemansJan 02, 2021Guru - Experienced User
Its because its set by the ISP.
Its built into the firmware on these combo devices for IPV6 to be enabled.
there's not a disable option unless the ISP requests that firmware option. Most don't.
