tiweintraub
Dec 23, 2020Follower
Disable SIP ALG on CM500
Hello: I am trying to disable SIP ALG on my CM500-100NAS Cable Modem. I am arunning v1.01.14 Firmware. Under the advanced tab, I don't have the options to go to SETUP-WAN SETUP and disable SIP. W...
Dec 23, 2020Guru - Experienced User
What you're missing?
The CM500 is a modem only. It isn't a router.
There's no disabling it on a modem.
Maybe on a modem/router combo device but not strictly a modem.
