Rabid's avatar
Rabid
Follower
Feb 22, 2022
Disabling AP isolation on C7000v2
Does anyone know how to disable Client Isolation on routerlogin.net? Cant find the setting anywhere. Need to disable to update a smart thermostat.
  • FURRYe38's avatar
    I don't believe this is a feature available on this gateway modem.
    Review the user manual for additional information.
    Try using the DMZ for the device temporarily to see if it will update.
    Netgear has set up a community forum specifically for the Cable Modem products. Most of the people who watch that forum are more likely to have experience with Cable modems (C and CM series) products. Might be more likely to find someone who has a solution if the question is posted there:
    https://community.netgear.com/t5/Cable-Modems-Routers/bd-p/home-cable-modems-routers
    Thank you.
  • plemans's avatar
    what smart thermostat are you trying to update?
    Where is it failing in the process?
    Have you contacted the manufacturer of the thermostat?
