craig-wagner
Feb 26, 2021Guide
Disassemble CM1150V
My CM1150V recently got knocked off my desk. There is now a rattling sound inside and it won't power on. I figured I'd take a shot at opening it up to see if I might be able to fix it myself. Does an...
Feb 26, 2021Guru - Experienced User
You might take it to a hardware store or home depot or lowes and have someone help you fit something to those screws. I don't off hand thought i problaby have something that does fit...:smileyembarrassed:
