myrmidon009
Sep 20, 2019Aspirant
DNS Settings Grayed Out
I'm trying to change the DNS Settings on my cable gateway. It's an AC1900/C6300BD wireless cable data gateway and my internet provider is Cox. I have logged in using the address for the modem. How...
- Sep 24, 2019
I gave Cox a call. They said that that functionality is disabled on newer modems, and they cannot change it. Also, all future modems will have the same functionality disabled. It's time to switch to a new ISP. Thank you for trying to work through this with me.
Sep 21, 2019Guru - Experienced User
Do you have any parental controls enabled? Disable these as these tend to use specific DNS addresses thus disabling the use of configuring the DNS addresses here.
