myrmidon009
Sep 20, 2019Aspirant
DNS Settings Grayed Out
I'm trying to change the DNS Settings on my cable gateway. It's an AC1900/C6300BD wireless cable data gateway and my internet provider is Cox. I have logged in using the address for the modem. How...
- Sep 24, 2019
I gave Cox a call. They said that that functionality is disabled on newer modems, and they cannot change it. Also, all future modems will have the same functionality disabled. It's time to switch to a new ISP. Thank you for trying to work through this with me.
myrmidon009
Sep 21, 2019Aspirant
Parental controls have never been enabled on the modem. I had one previously on the computer, but it has been uninstalled. AVG Antivirus is still active, if that might make a difference.
I should mention that I was able to select the button after I unclicked 'Use Gateway as DHCP Server' on the 'LAN Setup' page. But when I entered the new DNS servers and clicked 'Apply', the new addresses would not be used; the old ones would still be listed on the 'Gateway Status'. Shortly (maybe 10 minutes) after unclicking that button, 'Use Gateway as DHCP Server', however, I was no longer able to log into the modem. When I typed in the address, it was say that it was not able to find that page. I had to do a factory reset of the modem to be able to log in again.
Sep 23, 2019Guru - Experienced User
Wondering if your ISP is making any configuration changes to your modem. Something to ask them about.
- myrmidon009Sep 24, 2019Aspirant
- FURRYe38Sep 25, 2019Guru - Experienced User
Eeeks. Thanks for letting us know. I would go with a stand alone modem unit then connect up your own external wifi router.
Good Luck.
myrmidon009 wrote:I gave Cox a call. They said that that functionality is disabled on newer modems, and they cannot change it. Also, all future modems will have the same functionality disabled. It's time to switch to a new ISP. Thank you for trying to work through this with me.
