myrmidon009
Sep 20, 2019Aspirant
DNS Settings Grayed Out
I'm trying to change the DNS Settings on my cable gateway. It's an AC1900/C6300BD wireless cable data gateway and my internet provider is Cox. I have logged in using the address for the modem. How...
- Sep 24, 2019
I gave Cox a call. They said that that functionality is disabled on newer modems, and they cannot change it. Also, all future modems will have the same functionality disabled. It's time to switch to a new ISP. Thank you for trying to work through this with me.
myrmidon009
Sep 24, 2019Aspirant
Sep 25, 2019Guru - Experienced User
Eeeks. Thanks for letting us know. I would go with a stand alone modem unit then connect up your own external wifi router.
Good Luck.
myrmidon009 wrote:I gave Cox a call. They said that that functionality is disabled on newer modems, and they cannot change it. Also, all future modems will have the same functionality disabled. It's time to switch to a new ISP. Thank you for trying to work through this with me.
