zattack8203
Jul 13, 2022Aspirant
Docis 3.1 Netgear Modem Randomly Drops Connection
Hi there, I have a NetGear CM1000v2 with firmware V10.01.07. This past week the modem has been dropping the coax cable line repeatedly and is starting to get annoying. We had this modem for abou...
Jul 14, 2022Guru - Experienced User
You didn't include all your channels from from the ones you did, you have line issues.
Start with removing any amplifiers, signal attenuators, or splitters from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
If you can, include the full cable connections page and the event logs from after checking the lines highlighted above.
zattack8203
Jul 14, 2022Aspirant
Here is also the log
- plemansJul 15, 2022Guru - Experienced User
Try disconnecting the splitter.
Your upstream levels are high meaning the router is having to increase its output power just to communicate with the cmts. You also have range window violations which are power levels that are going outside of parameters.
Try to connect right where it comes into the home and not with any splitters or adding extra cabling to the line.
