zattack8203
Jul 13, 2022Aspirant
Docis 3.1 Netgear Modem Randomly Drops Connection
Hi there, I have a NetGear CM1000v2 with firmware V10.01.07. This past week the modem has been dropping the coax cable line repeatedly and is starting to get annoying. We had this modem for abou...
zattack8203
Jul 14, 2022Aspirant
Here is also the log
Jul 15, 2022Guru - Experienced User
Try disconnecting the splitter.
Your upstream levels are high meaning the router is having to increase its output power just to communicate with the cmts. You also have range window violations which are power levels that are going outside of parameters.
Try to connect right where it comes into the home and not with any splitters or adding extra cabling to the line.
