Whogordon's avatar
Whogordon
Docsdevresetnow cm1200
Had this modem about a month or two, no problems. The last few days at the same time it is resetting. Docsdevresetnow. Prior to that and continuing after the reset as shown in event log i am getting event codes 20 and 22 on channel 159.
I have not changed any setting ( factory settings)on the modem or the hook up/ wiring since i have installed this modem.
  • Think i solved my own problem as the coaxial cable was not screwed in all the way🤦‍♂️Shut it down disconnected powered up and now clear event log and Zero correctables. Thanks guys lol
  • pt. 2 event log continued
  • pt. 3 event log continued
  • Screenshot of the locked channel page after it the modem has reset
