HomeTown
Mar 28, 2020Aspirant
Docsis 3.0 vs. Docsis 3.1 for Cable modem router for Nighthawk C7100V
Does a Docsis 3.1 cable modem router have achieve higher wifi speeds than a Docsis 3.0 device? Please give an example.
Mar 28, 2020Guru - Experienced User
Try a different testing site.
try dslreports.org
or switching servers on the speedtest app. It defaults to the one with lowest ping but that isn't always the best.
Also, you can download a wireless channel scanner for free usually. Try downloading on and doing a wireless channel scan.
Maybe there's interference and it needs to be switched.
The channel settings are on the same page as the SSID password.
Usually 2.4ghz is set on auto. the 5ghz you pick the channel.
michaelkenward
Mar 29, 2020Guru - Experienced User
If you need more help, you might do better over in the appropriate section for your device:
Cable Modems & Routers
