westerj
Jun 04, 2020Aspirant
DOCSIS and Optimum - how to keep current
Hi, If I purchase a cable model and my ISP doesn't flash upgrade it, how does that keep me secure? I understand that the DOCSIS model REQUIRES the ISP flash update from the cable side. ...
- Jun 05, 2020
Again something to ask that ISP about.
Most experiences I have with mine, and they update FW for my own modems, is that they will push FW soon after, during the install process or maybe a day or two later. But thats my ISP service. I can't say what others will do.
If you feel the unit is just bad, then return it, contact NG support and as about an RMA if thats an option, or find a new modem.
Jun 04, 2020Guru - Experienced User
Ask the ISP to upgrade the modems FW. If they won't then thats there policy and your modem will be stuck at what ever was loaded on it. You can't update FW or modify FW on any cable modem. Find an ISP that will update user owned modems or you'll have to either accept the CM modem what it won't get any updates from an ISP that won't update FW or use one of the ISP modems.
Good Luck.
westerj
How can it be said a cable modem works or doesnt if the isp wont do their part of the docsis arrangement? This is a right-to-repair issue ( google "right to repair" "John deere"). I bought the hardware,i should be able to update it. Its not wise to run a dead end version. The docsis devices have a maintenance strategy,that needs a rethink.
- FURRYe38Jun 05, 2020Guru - Experienced User
Something to discuss with the ISP.
Good luck.
- westerjJun 05, 2020Aspirant
So.. if I plug into another ISP, who does support this model, chances are they'd flash it ?
The model appears broken though. I bought it, but cant repair it?
