Fragsinvegas
Jul 12, 2022Follower
DOCSIS question
Hello- I have Cox Gigablast, currently getting from 500-700 down speeds Arris SB8200 is supposed to show blue up/down lights when running 3.1, and all green when 3.0. My lights are all green. I co...
Jul 12, 2022Guru - Experienced User
Something to post about over in the Arris forums regarding there product.
Though possible your power levels could be a bit too high and you have some criticals on the events page and correct and un-correctables that should be mostly zeros.
https://www.duckware.com/tech/solving-intermittent-cable-modem-issues.html
https://highspeed.tips/docsis-events/
Something to have your ISP check on and check for coax splitters and fittings to ensure they are snug. Remove any splitters as these can cause problems.
Contact the ISP and Arris.
Good Luck.
- plemansJul 12, 2022Guru - Experienced User
FURRYe38 is correct, you'd be better on arris's forum.
With that said, your power levels are high, you have a bunch of errors, and your logs are indicating line issues.
Start with removing any amplifiers from the coax.
From there check the line for kinks, damage, moisture in the line.
Check the connectors for improperly made ends, foil touching the copper coax line, bad/old/cheap connectors, or corroded connections. Replace them if you do.
If you can, simply connect the modem right where the coax comes into the home. This prevents wiring in the home from being the issue. And some ISP’s charge if the wiring issue is in the home. So this helps prevent this.
