DaisyM's avatar
DaisyM
Does CM500V support VDSL2?
I already have a CM500V modem,I wonder to know that is it support VDSL2?
Thanks
  • C and CM series modes are only for Cable ISPs. No DSL support.
    D and DM series are modems that support DSL.
  • FURRYe38's avatar
    • DaisyM's avatar
      DaisyM
      Thank you very much,I might need to buy a new modem:smileylol:
      • FURRYe38's avatar
        Check with your ISP before you buy to see what is supported first.
        Good Luck.
