CBV
Nov 01, 2020Tutor
Does CM500V works with NON X-Finity voice services
Can somebody confirm if CM500V could work with NON XFINITY voice services. I mean use differente SP that has voice service but is not voice XFINITY service. Thanks Regards
- Nov 01, 2020
Yes it's supported on XF...
Nov 01, 2020Guru - Experienced User
Ask your ISP about this. I presume not.
CBV
Nov 01, 2020Tutor
Dear FURRYe38,
Thanks for the info. I already asked to cable provider but I have not received a clear answer, they only say the modem requiered must be DOCSIS 3.0, 16 x 4, voice but not XFINITY.
Thanks
- FURRYe38Nov 01, 2020Guru - Experienced User
Most of the NG modems with Voice support only work on CC or Xfinity services. Ohers ones, they should have this information as they already know what modems they support on there network.
