CJinVA
Jul 18, 2019Guide
Does it matter if my modem/router US and DS lights are flashing?
I have a Netgear c7000v2 modem/router. Cox, Northern Virginia is the provider/ISP. Normally, the internet light is on and the upstream and downstream lights are steady green. The last couple of da...
Jul 18, 2019Guru - Experienced User
Check the user manual for LED behaviors.
Have the ISP check signal line quality up to the modem.
Be sure that there are not coax line splitters between the modem and ISP service box.
- CJinVAJul 18, 2019Guide
I had Cox refresh the modem and now I am back to a solid green internet connection, a solid green downstream connection (177 on speedtest), and a solid amber upstream connection (10.5 on Speedtest). I have only one upstream channel locked and the speed is 57dBmv, which I have read is too much power for any other channels to lock. I think this is a ISP/Cox signal problem, but anyone have any ideas?
- FURRYe38Jul 18, 2019Guru - Experienced User
The ISP tech should know the recommended levels.
