Leroy_D's avatar
Leroy_D
Tutor
Jan 25, 2023
Does Netgear make pon and FTTH modems?
I own a Netgear CM3700 10gb dosic 3,1 Coaxial modem.   I really love this thing, and it was 400$ at one point. I truly thought I'd never replace it in my entire life. I upgraded my home service to ...
  • plemans's avatar
    Jan 26, 2023
    A couple things.
    1. there isn't a cm3700.
    2. the C3700 isn't 10gb or docsis 3.1 so not sure what device you have
    Netgear doesn't make an ont/fibre gateway. But most fibre ISP's provide you with either an ONT or a gateway device to connect your router to. You just need a router only device to use.
