Leroy_D
Jan 26, 2023Tutor
Does Netgear make pon and FTTH modems?
I own a Netgear CM3700 10gb dosic 3,1 Coaxial modem. I really love this thing, and it was 400$ at one point. I truly thought I'd never replace it in my entire life. I upgraded my home service to ...
- Jan 26, 2023
A couple things.
1. there isn't a cm3700.
2. the C3700 isn't 10gb or docsis 3.1 so not sure what device you have
Netgear doesn't make an ont/fibre gateway. But most fibre ISP's provide you with either an ONT or a gateway device to connect your router to. You just need a router only device to use.
Jan 27, 2023Guru - Experienced User
The C7800 won't work as a router only device.
It has a modem only mode and a modem/router mode. It needs that coax input.
there might be a way to make it work as a sort of access point but not sure if it'll work on that device.
You have to disable dhcp on the c7800 and give it a static ip address thats in the range of the primary gateway's IP range.
