JBLAZE412
Mar 04, 2022Initiate
DOES NIGHTHAWK ROUTERS WORK WITH SATELITE INTERNET MODEMS?
Hey all I have crrrrrap ass Hughsnet internet service smh only choice I have does my router aka Nighthawk compatitable with Sat Internet ?? Or just cable? If just cable which gaming router should I g...
Mar 04, 2022Guru - Experienced User
Usually hughes net has a gateway you need to use. From there you can attach another router that you prefer.
It isn't going to give you any faster speeds as usually the bottleneck is the hughes net connection.but it can give you further coverage.
