UtOh
Apr 21, 2022Follower
does not broadcast a ssid anymore
I cannot find a broadcast SSID from my router or set it up. The nighthawk app won't find the router. The only way I can use my router wirelessly isthrough logging into my ISP service providers SSID. ...
Apr 21, 2022Guru - Experienced User
Factory reset the modem by pressing the reset button for 10 seconds then release. Give it another 10 seconds then pull the power adapter from the wall for 30 seconds. Plug back in and after the modem is ready, connect 1 wired PC to the back of the modem and use a web browser to setup the modem from scratch at 192.168.1.1 or might be at 192.168.0.1.
