UtOh
Apr 21, 2022Follower
does not broadcast a ssid anymore
I cannot find a broadcast SSID from my router or set it up. The nighthawk app won't find the router. The only way I can use my router wirelessly isthrough logging into my ISP service providers SSID. ...
michaelkenward
Apr 22, 2022Guru - Experienced User
I don't understand that. How does your ISP provide an SSID?
That is something that the router delivers.
Before drastic measures like setting up the thing all over again, try some simple troubleshooting measures.
Are the wifi LEDs lit up at the bottom on the front of the modem/router?
What about the one on the right? Tried pressing the on/odd switch there?
The best way to set up and manage the router is with the browser graphical user interface with a wired connection from a PC.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
