UtOh
Apr 21, 2022Follower
does not broadcast a ssid anymore
I cannot find a broadcast SSID from my router or set it up. The nighthawk app won't find the router. The only way I can use my router wirelessly isthrough logging into my ISP service providers SSID. ...
Apr 22, 2022Guru - Experienced User
A little better idea of your setup might help.
1. what netgear router do you have?
2. what firmware is on it?
3. what modem/gateway is it connected to?
4. Is your netgear in router mode or access point mode?
5. did the wifi on/off button get hit? Push and hold it for 2 seconds.
