compufix4u's avatar
compufix4u
Does the CG3000Dv2 support DDNS?
Does the CG3000Dv2 support DDNS or is it as big of a piece cr*p as I beleive it is?
  • Thanks for your help DarrenM I really do appreciate it. It simply confirms that I should do a little bit better research.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello compufix4u
    It does not look like the CG3000dv2 supports DDNS
    DarrenM
    • compufix4u's avatar
      compufix4u
