FightingFurball
Nov 11, 2021Aspirant
Does the CM2050V Cable Telephony Modem support Faxing?
I recently replaced my Xfinity Modem with the Nighthawk CM2050V Cable Telephony Modem. Now, with this new modem, I am unable to send a Fax from my HP Printer. I had no problem Faxing documents before with the old Xfinity Modem.
Has anyone with the CM2050V successfully faxed something?
Thanks.
1 Reply
According to the "applies to" for the can you connect it article, it says yes.
https://kb.netgear.com/000060515/Can-I-connect-a-fax-machine-to-my-cable-telephony-modem
