Josh1403's avatar
Josh1403
Follower
May 01, 2021
Does the Nighthawl D7000 work with Nighthawk tri band mesh 1800
HI, I have the Nighthawk 1900 D700 and working fine but wondering if it will work with the AX1800 firstly and then scale up to wifi 6?
1 Reply
  • > HI, I have the Nighthawk 1900 D700 [...]
       Some of that is close to an actual model number.  Look for "Model" on
    the product label.  A model D7000v2 also exists.
    > [...] wondering if it will work with the AX1800 [...]
       Like "AC1900", "AX1800" is a speed, not a model number.
    "work" how?  Did you want to use the D7000[vX] as a modem, or what,
    exactly?
       If you use a Wi-Fi 6 router, then you should have Wi-Fi 6.  If you
    connect a Wi-Fi 6 router to your (unspecified) ISP through a (much
    slower) DSL modem, then it's not obvious how big the benefit of faster
    wireless would be.
