TechFungus
Nov 02, 2020Aspirant
DoS attack from employer VPN
I have a C3700 with the most recent FW V2.02.22. When I initiate a VPN connection from my work laptop, CAT5e not wireless, I can establish a connection for a couple of minutes and then my entire home...
- Nov 13, 2020
I got the VPN to work finally. Not sure if it is due to this being an older piece of hardware or not but the answer was to disable DoS protection. Something about how this device behaves with the VPN connection acknowledgement from my employer's server and the DoS protection logic just wasn't working. Maybe looking at a future cable modem replacement or adding a dedicated router behind it and letting it just be a cable modem.Bottom line is that I have a working connection. Thanks.
TechFungus
Thanks. I have been working with my IT team and it was they that suggested whitelisting the IP. I had asked if port forwarding would be an option but they pointed me to the firewall. I could setup port forwarding and test.
Is there no possiblitiy to edit the firewall settings on the c3700 N600?
Nov 02, 2020Guru - Experienced User
Not sure if there is any configuration on this model modem...something to check in the user manual, if not, then try the Port Forward configuration.
- TechFungusNov 04, 2020Aspirant
Nothing in the manual reagrding access to the firewall configuration, at best I can disable Port scan and DoS protection or disable the firewall altogether. I will post my findings with the Port Forwarding option once I have a chance to give it a go.
- FURRYe38Nov 04, 2020Guru - Experienced User
Keep us posted...
- TechFungusNov 10, 2020Aspirant
Unfortunately no progress, still getting DoS SYN flood from the VPN server. Not sure that port forwarding is the answer, I have tried several configurations, same port for both ends, fixed port for the VPN server and none reserved for my PC, I have even tried a custom port forward setup in the same two ways I mentioned before and there is no way I get a connection to stick. At best I can authenticate to my employer VPN server and at the point where the tunnel is being established, the internet connection drops and I can't access anything beyond my home LAN. The log on the C3700 shows the DoS attack at the time when the tunnel should be getting established. Could my C3700 not be sending ACKs? Any other ideas? Reset the C3700 back to factory and reload the configuration?
