steveberry10
May 29, 2022Tutor
[DoS attack] LAND Attack SPT:2190 DPT:2190
Hi All, I had an issue last week with my Orbi system. Long story short, I was receiving a ton of DDoS messages from all my devices attached to my home network. After talking this over with a fe...
May 29, 2022Guru - Experienced User
Anything related to this?
https://www.radware.com/security/ddos-knowledge-center/ddospedia/land-attack/
- steveberry10May 29, 2022Tutor
Thanks but I don't see anything in that link other than a description of the problem? Anyway, yes that basically describes it. However it's not affecting my internet service.
I did see an old article from around 2015 where these were caused by having Access Control turned on...and I set that up at the same time I updated the firmware. In fact Access Control was on when I rebooted after the firmware update. Hmmm...
Anyay, I am still getting the NULL attack messages as well. I've logged an incident with my ISP. Hopefully these are just false positives.
- FURRYe38May 30, 2022Guru - Experienced User
Might try a factory reset and setup from scratch. This time, don't setup Access Controls or any additional features. Check the logs.
- steveberry10May 31, 2022Tutor
Thanks Furry, I've thought about that. The thing is I see two types of attacks: the LAND attacks and the NULL attacks. The latter have a legit source IP which seem to be coming from China.
I've opened a ticket with my ISP and I'm waiting to hear back from them.
