steveberry10
May 29, 2022Tutor
[DoS attack] LAND Attack SPT:2190 DPT:2190
Hi All, I had an issue last week with my Orbi system. Long story short, I was receiving a ton of DDoS messages from all my devices attached to my home network. After talking this over with a fe...
kP206
Jun 15, 2022Guide
Hey crttrsfrttrs,
I have the same modem and Philips Hue 2nd gen hub with the same issues. After Comcast came over and replaced cable lines, it didn't fix the issue. And from what I found online, tons of people are having the same issues. I found out that downgrading the firmware will fix the rebooting. Here is the link to the other Netgear forum with the link to downgrade your firmware.
Hope this helps you guys!!
Omnitron
Jun 17, 2022Guide
I get LAND attack logs all the time since my CAX80 got updated to 2.1.3.7. And the attacks are listed as originating from my own IP address (Xfinity).
- OmnitronJun 25, 2022GuideStill getting LAND attacks from my own (ISP) IP address every 10/20/40 minutes, on CAX80 2.1.3.7. Did not occur on 2.1.3.5.
- tamanacoJun 25, 2022Apprentice
Same here... at about the same intervals using 2.1.3.7 - The source IP of the [DoS attack] LAND Attack SPT:2190 DPT:2190
messages is the ISP (Spectrum) assigned CAX80 Modem (WAN) address.
Today, for the first time, I got a series of [DoS attack] SYN Flood SPT:xxxxx DPT:xxxx messages like the one below. The SPT: Port number and DPT: Port number changes from message to message. I'm assuming these are random port numbers. The target (xx.xxx.xxx.xx:3359) is my ISP assigned address, but the source (193.239.86.210:55441) is unknown to me, and apparently, it's originating from Hong Kong. The series of about 10 consecutive messages stopped about two hours ago. Did anyone get similar messages?
Before anyone asks... yes, I've already followed the usual troubleshooting steps... Please, don't ask me to reboot or reset the CAX80.
[DoS attack] SYN Flood SPT:55441 DPT:3359 1 Sat Jun 25 14:31:49 2022 xx.xxx.xxx.xx:3359 193.239.86.210:55441
- OmnitronJun 25, 2022GuideLAND attacks from our own ISP IP address is a widespread issue since 2.1.3.7 and should be addressed here by Netgear. But other types of attacks (esp. ones originating from external IP addresses) are unexpected and probably real — you could maybe ask your ISP if they have further guidance.
