iammike
Nov 19, 2018Initiate
DoS attack: Teardrop or derivative - WAN goes unresponsive every five minutes or so
This isn't a new issue to me, but its increasing frequency has my connection to near useless levels.
When it happens, my network slows to a crawl or a stop and I can't even connect to the route...
_kalin
Mar 14, 2019Initiate
I purchuased C7000V2 to avoid renting comcast router then after a couples of months using it I started to lose internet connection progressively till the point i started to reset the router every 5 mins and I thought that was a comcast issue. I was trying to figuere out what was causing this issue for a week until i gave up and i called comcast yesterday.They came by and they didnt find anything wrong. then when i looked into the netgear router i found this "[DoS attack: Teardrop or derivative] from 133.2.159.224, port 0 1 Wed Mar 13 14:24:42 2019 124.58.185.53:0 133.2.159.224:0" -----------Those IPs belongs to Japan and Korea ------- I think the best opptions to avoid this kind of issues is moving to a different rounter and rent a comcast router again since I dont see any way to avoid this and Netgear devices are prone to be hacked.
Any idea what to do I will appriciate it .
Thanks
Kalin
iammike
I switched to an Arris and haven’t had a problem since. Won’t be buying Netgear again.
