EyepSix
Oct 31, 2020Follower
DoS attack, Teardrop or derivative, Ping of Death, strange IPv6 Parsing Solution
I have found a solution to this two year old, unresolved problem:
Summary of problem:
Router logs will show DoS attack, Teardrop or derivative, Ping of Death coming from a strange IP address. When you trace this IP, it will be weird from a foreign country.
The router will keep dropping connection due to these assumed D-DoS attacks.
Problem has not seen a firmware fix in two years.
Root Cause:
fqm889identified the root cause as firmware bug, where Netgear mis-parses IPv6 address.
ipv6 address:
xxxx:xxxx:aabb:ccdd:eeff:gghh:xxxx:xxxx
Change aa bb cc dd ee ff gg hh from heximal to decimal AAA BBB CCC DDD EEE FFF GGG HHH
Then you can find that AAA.BBB.CCC.DDD is your source and EEE.FFF.GGG.HHH is your destination of 'DoS' packets.
User fduate has provided a graphical represenation in the attached PNG photo.
Solution:
Self-assigned IPv6 addresses are causing this issue, and this is resolved by enabling DHCP for IPv6.
Navigate to:
Admin Panel > Advanced Tab > Advanced Setup > IPv6 > IP Address Assignment
Then click "Use DHCP server".
Copy "Router delegated prefix" (The value usually ending in /64)
Paste previous value in "Start IP Address" and edit last three characters "/64" to "3/60".
Click "Apply" and reboot.
Enjoy!
Something to let NG know about if you haven't already.
- craigdelgado0Aspirant
The LAN delegated prefix and the Start Address are the same except the "1" in front of the "/64" on the start address. When I try to change that to "3/60" I get an error that says "the start address is incorrect". I also tried to copy the LAN delegated prefix and change the last three to "3/60" as instructed, but same result. Doesn't seem to work on the C7000 modem/router.
- phipperdeeAspirant
Has anyone gotten this, or some other solution to work? Checking all the forums, it looks like this issue has existed for over 4 years. Endless DOS attacks from iPhone due to IP address glitch. Only solution: replace with different brand?
