Ale-Bun
Nov 25, 2020Aspirant
DoS Attacks from Level 3 Parent, LLC
Hello, For a while now i've been getting DoS Flooding attack from [DoS attack] ICMP Flood from 4.71.251.139 and another one from 35.181.49.150... and more. I run who's on both iP's and comes up a...
Nov 25, 2020Guru - Experienced User
See if your ISP will change your WAN IP address on the modem.
Also power OFF the modem for 1 minute or more if you can to see if the IP address will change on the modem.
Might contact your ISP for additional help and information.
- Ale-BunNov 25, 2020Aspirant
FURRYe38 wrote:See if your ISP will change your WAN IP address on the modem.
Starting with ISP WAN IP change and will see about troubleshooting more. Will update to see if this wlll resolve the issue.
Thank you,
vajim wrote:If you’re not able to reset your IP address on your own, you may contact your ISP directly to request a new address.
If you’re a frequent target of DDoS attacks, you can ask for a “dynamic IP,” which changes your IP address on a regular schedule. However, many ISPs don’t allow consumer-level users to hold a dynamic IP and it often is not effective against a determined attacker. Additionally, a dynamic IP may lead to technical difficulties with your chosen streaming site if you’re a regular game streamer.
good luck
vajimAccording to my ISP, at consumer level, IP addesses set to switch dynamically after turning the Modem Off for 4 to 5 hours. However, that does not seem to help resolve the issue. The next option i have is to use a Static IP.
