Juventus_nz
Mar 04, 2017Follower
DoS Attacks in the logs
Hey guys I have been getting disconnected from the internet at different times over the past week. At first i thought it might have been an ISP issue, spoke to them and multiple line checks revealed ...
DarrenM
Mar 07, 2017Sr. NETGEAR Moderator
Hello KClaeys
I checked and here is where your Dos attacks are coming from
https://ant.isi.edu/datasets/about.html
also are you seeing any type of timeouts in your logs?
DarrenM
- KClaeysMar 07, 2017Aspirant
Hi Darren,
Thanks for the info. I am planning on writing them a scathing letter to get them to stop. I don't think it is all them though. Anyway, I checked the logs and this is the first thing I saw:
DoS attack] AIF:Dropped INPUT packet: PROTO:TCP SPT:9090 DPT:22 1 Tuesday, 07 Mar 2017 11:17:48 68.102.73.127 221.229.160.210 [DoS attack] ICMP Flood from 206.117.25.90 1 Tuesday, 07 Mar 2017 09:49:06 68.102.73.127 206.117.25.90 Any ideas on what to do? I am seriously upset because of the dropped internet. This is really killing my paycheck.
- DarrenMMar 08, 2017Sr. NETGEAR Moderator
Can you post the power levels on the Cable connection page check to see if anything is off. You may also want to check if you have a cable splitter connected to the modem they can cause some issues try plugging straight to the wall. Also have you had your ISP come out and check your lines?
DarrenM
- KClaeysMar 08, 2017Aspirant
I don't use a splitter, so I know that itsn't the problem. I'm going to have the cable company come out, even though they all tell me it's on my end. Here are the logs for the power. Please let me know if you see anything odd.
<tabindex=-1>Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR Correctables UnCorrectables 1 Locked QAM 256 121 813000000 Hz -7.7 dBmV 37.6 dB 0 0 2 Locked QAM 256 122 819000000 Hz -7.7 dBmV 37.6 dB 17 0 3 Locked QAM 256 123 825000000 Hz -7.2 dBmV 37.6 dB 0 0 4 Locked QAM 256 124 831000000 Hz -7.5 dBmV 37.6 dB 0 0 5 Locked QAM 256 125 837000000 Hz -7.7 dBmV 37.6 dB 0 0 6 Locked QAM 256 126 843000000 Hz -8.2 dBmV 38.6 dB 0 0 7 Locked QAM 256 127 849000000 Hz -8.2 dBmV 37.6 dB 0 0 8 Locked QAM 256 128 855000000 Hz -8.7 dBmV 37.6 dB 0 0 9 Locked QAM 256 137 909000000 Hz -9.7 dBmV 37.3 dB 3424 48193 10 Locked QAM 256 138 915000000 Hz -10.2 dBmV 34.3 dB 4098 68314 11 Locked QAM 256 139 921000000 Hz -10.5 dBmV 37.6 dB 2086 41253 12 Locked QAM 256 140 927000000 Hz -10.7 dBmV 36.6 dB 284 7327 13 Locked QAM 256 141 933000000 Hz -11.4 dBmV 36.3 dB 0 0 14 Locked QAM 256 142 939000000 Hz -11.7 dBmV 36.3 dB 0 0 15 Locked QAM 256 143 945000000 Hz -12.5 dBmV 36.3 dB 0 0 16 Locked QAM 256 144 951000000 Hz -13.3 dBmV 35.7 dB 0 0 <tabindex=-1>Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 1 2560 Ksym/sec 21600000 Hz 41.3 dBmV 2 Locked ATDMA 2 5120 Ksym/sec 26500000 Hz 41.3 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 33000000 Hz 42.8 dBmV 4 Locked ATDMA 4 2560 Ksym/sec 37900000 Hz 42.8 dBmV
