Juventus_nz
Mar 04, 2017Follower
DoS Attacks in the logs
Hey guys I have been getting disconnected from the internet at different times over the past week. At first i thought it might have been an ISP issue, spoke to them and multiple line checks revealed ...
DarrenM
Mar 08, 2017Sr. NETGEAR Moderator
Can you post the power levels on the Cable connection page check to see if anything is off. You may also want to check if you have a cable splitter connected to the modem they can cause some issues try plugging straight to the wall. Also have you had your ISP come out and check your lines?
DarrenM
KClaeys
Mar 08, 2017Aspirant
I don't use a splitter, so I know that itsn't the problem. I'm going to have the cable company come out, even though they all tell me it's on my end. Here are the logs for the power. Please let me know if you see anything odd.
| <tabindex=-1>Downstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
| <tabindex=-1>Upstream Bonded Channels | |||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||||
