Juventus_nz
Mar 04, 2017Follower
DoS Attacks in the logs
Hey guys I have been getting disconnected from the internet at different times over the past week. At first i thought it might have been an ISP issue, spoke to them and multiple line checks revealed ...
DarrenM
Mar 15, 2017Sr. NETGEAR Moderator
Hello Mrcarrotlll
Are you able to post your logs and levels of the modem it could give a better Idea of why the disconnects are happening.
DarrenM
- MrCarrotIIIMar 16, 2017Aspirant
<tabindex=-1>Downstream Bonded Channels Channel Lock Status Modulation Channel ID Frequency Power SNR 1 Locked QAM256 102 801000000 Hz 2.1 dBmV 38.7 dB 2 Locked QAM256 101 795000000 Hz 2.0 dBmV 38.6 dB 3 Locked QAM256 103 807000000 Hz 2.1 dBmV 39.0 dB 4 Locked QAM256 104 813000000 Hz 2.0 dBmV 39.0 dB 5 Locked QAM256 109 843000000 Hz 1.1 dBmV 38.6 dB 6 Locked QAM256 110 849000000 Hz 0.7 dBmV 38.6 dB 7 Locked QAM256 111 855000000 Hz 0.2 dBmV 38.0 dB 8 Locked QAM256 112 861000000 Hz -0.1 dBmV 37.8 dB <tabindex=-1>Upstream Bonded Channels Channel Lock Status US Channel Type Channel ID Symbol Rate Frequency Power 1 Locked ATDMA 2 5120 Ksym/sec 21984000 Hz 44.8 dBmV 2 Locked TDMA and ATDMA 1 2560 Ksym/sec 17154000 Hz 44.0 dBmV 3 Locked ATDMA 3 5120 Ksym/sec 28414000 Hz 45.5 dBmV 4 Locked ATDMA 4 5120 Ksym/sec 34844000 Hz 45.5 dBmV
