psvgc
Dec 17, 2016Aspirant
Dos Attacks
i am noticing a wole slew of dos attacks in my cable modem router log its ping of death, tear drop, illegal fragments.. the wifi is being very slow my isp is spectrum(time warner cable), sho...
TheEther
Dec 17, 2016Guru
The default setting is unchecked, meaning that it Port Scan and DoS protection is enabled. There are a small number of people here, myself included, who believe that there are flaws in Netgear's code and that it misidentifies some packets as an attack. Turning off this feature could help in some of those cases. Unfortunately, most people fear that turning it off would somehow leave your home network wide open to the Internet. This is not true.
You should determine whether the slow Wi-Fi and DoS attacks are related. They may not be necessarily so. Slow Wi-Fi could be caused by interference or congestion from other networks. The simplest thing to do is to experiment with changing Wi-Fi channels. A Wi-Fi analyzer program can greatly help with finding a good channel.
If you have a wired machine, then you should see if it too has slow Internet. That would lend more credence to the DoS attack being real.
- psvgcDec 18, 2016Aspirant
TheEther thanks for quick response.
1. when i wired computer to the modem the speed was wayyyy fast
i installed netgear wifi analytics app and tried to see the signal.. the dignal strength stays 4% and teeters between -50dbms and -60dbms.. i am in the same room as the modem router and chose the best channel it suggested
what do i need to do to make this better
- TheEtherDec 18, 2016Guru
Is the wired computer slow going through the router?
-50 dBm to -60 dBm is a decently good signal strength, but that's at odds with a reading of 4%. It's possible that there are other sources of radio noise that could be interfering with Wi-Fi. Baby monitors, 2.4 GHz cordless telephones, Bluetooth and microwave ovens for example. Can you switch to 5 GHz?
