mrbs9271
Apr 06, 2019Aspirant
Double Nat Error with C7000v2
I am getting a double NAT error and strict on the xbox one, what can i do to fix this, i have tried multiple sites, however, we have the cable modem/router version, not just router version, so most f...
Apr 12, 2019Guru - Experienced User
Who is your ISP?
Is the C7000 working in router mode and connected to the ISP services via it's RG6 cable?
How is the xbox connected to the modem? Wireless or wired?
Is Instant ON enabled on the xbox. Disable this.
Another way to check to see if the xbox gets OPEN NAT would be to configure the C7000 for modem only mode. Directly connect the xbox to the modem only and see what status the xbox gets, if still moderate or strict, possible there mabye a NAT routing upstream from where your at. Having multiple NATs can cause problems.
mrbs9271 wrote:
I am getting a double NAT error and strict on the xbox one, what can i do to fix this, i have tried multiple sites, however, we have the cable modem/router version, not just router version, so most fixes i found wont work. I just bought the modem router to use here at the campground we have an annual site at since they sell us cheep netgear modems, we wanted something higher end with parental controls, hoping not to have the need for a modem and router due to space, but looks like i might have to if i can not get this fixed. Please help with what i can do??
mrbs9271
Apr 12, 2019Aspirant
i replied with all this info above your message
