mrbs9271
Apr 05, 2019Aspirant
Double Nat Error with C7000v2
I am getting a double NAT error and strict on the xbox one, what can i do to fix this, i have tried multiple sites, however, we have the cable modem/router version, not just router version, so most f...
mrbs9271
Apr 12, 2019Aspirant
I have tried both wired and wireless. Problem is if I make it modem only, we won't be able to use the Wi-Fi, I would then have to buy a separate router which is the whole reason I bought the combo
Apr 12, 2019Guru - Experienced User
The reason for switching it over to modem only mode is if you have it in that mode and you connect the xbox and then still have the nat problem. Its either the xbox settings or your provider.
Once you've ascertained that, you can switch back to regular router mode.
