Acharest23
May 18, 2020Aspirant
Down arrow light blinking c6220
We just moved and switched from spectrum to cox, I plugged in the c6220 and the down arrow is blinking green. Cox says that all is well on their end and to contact Netgear. The 5 and 2.5GHz lights are...
May 18, 2020Guru - Experienced User
Have the ISP check the signal and line quality UP to the modem.
Be sure there are no coax cable line splitters in the between the modem and ISP service box.
Be sure your using good quality RG6 coax cable up to the modem.
